Hi all, I'm facing a problem with an application that uses certificate with private certification authority.
I have an error when I try to instantiate a map with only basemap (no ESRI basemap but 1 service published on server where certificate is installed).
Domain specific configurations require that hostname aware checkServerTrusted(X509Certificate[], String, String) is used
I tried to apply workaround at this LINK , but it still doesn't work.
Anyone has the same problem? Could you help me?
TIA
Alder
