From further analysis, same situation happens in the Collector for ArcGIS in Google Play (Version 10.2.2):
To regenerate the issues:
Step 1:
Select any map in available in the Collector, we selected �??Community Addressing�?�
Step 2:
After entering the map, zoom out a little bit (as we want to realized the map cannot be updated when the map is zoomed in programmatically). Then perform 2 or more single taps (Do not double tap, as the map zoom in then) on the screen
[ATTACH=CONFIG]32717[/ATTACH]
Step 3:
Select a feature on the map
[ATTACH=CONFIG]32716[/ATTACH]
Step 4:
Select the �??Zoom to�?� in the menu
[ATTACH=CONFIG]32715[/ATTACH]
Step 5:
The location is zoomed in, and the dynamic layer (GraphicsLayer we believe) got updated. However, the base tiles are never getting refreshed.
[ATTACH=CONFIG]32713[/ATTACH]
Step 6:
The only way to make the base tile refresh is to do a pan / zoom manually.
[ATTACH=CONFIG]32714[/ATTACH]
Just a few single tap cause the issues. The situation is quite annoying for those who often use something like MapView.zoomToScale(Point, float) to show a location in MapView.
