Hello esri community,
I'm trying to show a callout that needs to be in the same callout window except without the extra white space that I've marked with red.
My implementation is the following
<?xml version="1.0" encoding="utf-8"?>
<resources>
<calloutStyle
borderWidth="0"
cornerRadius="20"
leaderLength="10"
padding = "0"
margin = "0"
leaderPosition="LOWER_MIDDLE"
leaderWidth="20" />
</resources>
<LinearLayout
android:layout_height="wrap_content"
android:layout_width="wrap_content"
android:orientation="vertical"
xmlns:android="http://schemas.android.com/apk/res/android">
<com.google.android.material.textview.MaterialTextView
android:background="@drawable/title_layout_bg"
android:backgroundTint="@color/colorPrimary"
android:id="@+id/title"
android:layout_width="250dp"
android:padding="10dp"
android:textSize="18sp"
android:textColor="@android:color/white" />
android:id="@+id/description"
android:layout_marginTop="8dp"
android:layout_width="match_parent"
android:maxLines="2"/>
android:layout_gravity="end"
android:id="@+id/readMore"
android:layout_marginBottom="8dp"
android:layout_marginEnd="16dp"
android:padding="5dp"
android:text="@string/read_more" />
</LinearLayout>
No matter what I do there's always extra white space around the view.
Any help?
