Adding graphics to AGSWebMap
2464
12
04-04-2012 10:17 PM
c_f_ong
New Contributor III
Hello
I've created an AGSWebMap and displayed it in an AGSMapView. However, I've problems now to add AGSGrpahic objects to the map view. No problem if I were to use AGSTiledMapServiceLayer instead of AGSWebMap. Is this the expected behaviour with using AGSWebMap ?
Thanks.
Rgds
Ong CF
c_f_ong
New Contributor III
Unfortunately, there is not way to over come this. The feature collections can be edited only on arcgis.com.
Yes!
Regards,
Nimesh
Hi Nimesh
I'm coming back to this thread with the release of Version 2.3. That is, can the limitation as discussed above be overcome with Version 2.3? Would it work if the webmap is hosted via ArcGIS on-line subscription?
Thanks.
Rgds
Ong CF
NimeshJarecha
Unfortunately, No, there is no way to overcome that limitation, not with v2.3 or ArcGIS Online subscription. 😞
Regards,
Nimesh
c_f_ong
New Contributor III
Hi Nimesh
Thanks for your reply.
Rgds
Ong CF
