AGSPictureMarkerSymbol rotate / angle without effect
2976
6
12-07-2010 04:53 AM
ManfredReinart
Hello,
I am trying to place a PictureMarkerSymbol with a given rotation angle on to of line objects with a given slope. Objective is to place the PictureMarkerSymbol orthogonally to the axis of the line.
So far I did not manage to achieve any effect.
Setting the angle attribute of the PictureMarkerSymbol before creating a graphic based on the symbol does not have any effect.
AGSPictureMarkerSymbol *pms = [AGSPictureMarkerSymbol  pictureMarkerSymbolWithImageNamed:@"picturename.png"];
pms.angle = 45.0;
Did anyone already manage to achieve this using ArcGIS IOS SDK 1.0?
Same for SimpleMarkerSymbol
    AGSSimpleMarkerSymbol *markerSymbol = [AGSSimpleMarkerSymbol simpleMarkerSymbol];
    markerSymbol.color = [UIColor yellowColor];
    markerSymbol.size  = 17;
    markerSymbol.style = AGSSimpleMarkerSymbolStyleDiamond;
    markerSymbol.angle = (CGFloat)30.0;
Setting angle has no effect.
Best Regards
Manfred
JeffPapirtis
New Contributor III
I am having a similar issue with the xoffset & yoffset.
I have set up my symbol as Follows:
AGSSymbol* symbol = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImageNamed:@"Redpin.png"];
symbol.xoffset = 10;
symbol.yoffset = 10;
Has anyone figured this out?
Thanks.
MiriEshel
New Contributor III
I have the same problem with AGSSimpleMarkerSymbol. The angle does not affect the symbol.
Did anyone figure it out?
Miri
Miri Eshel,
Systematics LTD.
Israel
NimeshJarecha
Unfortunately, at this time we can not set the angle of simple and picture marker symbols. This is a known issue.
Thanks for reporting!
Regards,
Nimesh
MiriEshel
New Contributor III
Hi Nimesh,
Thank you for your reply.
As far as I understand, the ArcGIS for iOS application does show a small arrow from the GPS location to the target while driving. I wonder how it is implemented there without rotating the symbol.
Thanks again,
Miri
MiriEshel
New Contributor III
Does AGSSimpleMarkerSymbol can refer the angle property in version 2.0.1 ?
Miri
NimeshJarecha
Yes!
Regards,
Nimesh
