Make a pulse animation in AGSPictureGraphics
1788
5
06-29-2017 07:33 AM
chiragshah4
Want pulse animation in agsgraphics in esri map ios
MarkDostal
Thank you for your question!  While we don't have anything specific to "pulse" graphics in the API, you can accomplish this by setting up your own timer and changing one or more graphicsOverlay, graphics, or symbol properties when the timer fires.  Below are two examples:  the first one changes the opacity of the graphics overlay containing the graphic to pulse; the second one changes the size of the symbol associated with the graphic.
The code to create the timer is as follows:
            var timer = Timer()
            timer = Timer.scheduledTimer(timeInterval: 0.02,
                                         target:self,
                                         selector: #selector(pulseGraphic),
                                         userInfo: nil,
                                         repeats: true)
And the "pulseGraphic" method to adjust the overlay opacity:
    var opacity: Float = 0.0
    var goingDown: Bool = true
    func pulseGraphic() {
        opacity = opacity + (goingDown ? -0.01 : 0.01)
        if opacity < 0.25 {
            goingDown = false
        else if opacity > 1.0 {
            goingDown = true
        else {
            animationGraphicsOverlay.opacity = opacity
Hope that helps.  If you have further questions, let me know.
Mark
MarkDostal
            var timer = Timer()
                                         target:self,
                                         userInfo: nil,
                                         repeats: true)
        if opacity < 0.25 {
            goingDown = false
            goingDown = true
        else {
Mark
chiragshah4
Is there any way to do this in android too?
MarkDostal
The code to change the opacity of the graphics overlay and the size of the marker symbol will be similar on Android.  I'm not familiar enough with it to say if Android has a similar timer to iOS, but I image they do.  If you need more help with that, please post a question on the Runtime Android forum, here:  https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-android
AlexanderNohe1
Hey Mark.  I ripped a lot of the android sample off of your iOS sample above.  I gave you a shout-out in the Readme for my Android sample in GeoNet:
Pulse Graphic Sample in Kotlin by nohe427 · Pull Request #309 · Esri/developer-support · GitHub
Hope that is okay.
MarkDostal
Alexander,
No problem, that's cool with me.  Glad you could use the code!
Cheers,
Mark
