OfflineFeatureEditingSample
2831
16
07-23-2014 09:08 AM
GISProgrammer
New Contributor III
I'm just getting my feet wet with the iOS esri examples (github).  I had a quick question about the OfflineFeatureEditingSample.  When/if I click the PLUS icon " + " the simulator and/or my device (phone) just goes black.  It doesn't matter if I'm in disconnect or not.  What should this button do?  Is it to add a new feature?  Is this a bug in the example or am I missing something.
Thanks
GISProgrammer
New Contributor III
OK Michael was correct...the new sample doesn't have the "Bar Button Item - Add" connected to the addFeatureAction.  I added the connection and now all is working.  I will make a push request using Github.
Thanks
YueWu1
by Esri Regular Contributor
Hello there,
Welcome to the ArcGIS Runtime SDK for iOS world. The sample works fine on my side. I wonder which version of the ArcGIS Runtime SDK for iOS are you using? Make sure using the latest version 10.2.3 ArcGIS SDK for iOS 10.2.3
Then, download the latest version of the sample code on Esri Github Esri/arcgis-runtime-samples-ios
Also, make sure using XCode 5 and iOS 7 SDK (or higher) are required to develop applications with ArcGIS Runtime SDK for iOS. Please check this link: System requirements—ArcGIS Runtime SDK for iOS
For the Plus icon, yes you are right, that is add new features on the map. The categories based on the feature server.
Here are the screenshots (Left: the main screen ; Right: once click the "+" button):
Screen Shot 2014-07-23 at 2.46.52 PM.png             Screen Shot 2014-07-23 at 2.47.02 PM.png
Hope this can help.
Best Regards,
GISProgrammer
New Contributor III
Hey Thanks Yue Wu,
Yes I have the newest SDK installed 10.2.3.
I have XCode 5 and 6.2 beta and both produce the same results.
The application runs fine and all the functionality works except the add feature button.
I have the latest Github example, just forked it yesterday.
The other thing I'm questioning is I was going through the ESRI/ArcGIS configuring your xCode project doc and it talked about adding dependent frameworks and libraries:
The ArcGIS framework depends on the following frameworks and libraries. Add them to your project's settings:
  • AppKit.framework
  • Cocoa.framework
  • CoreLocation.framework
  • Quartz.framework
  • QTKit.framework
  • OpenGL.framework
  • Security.framework
  • libc++.dylib
These are not added to this project..I'm looking under Build Phase - Link Binary With Libraries and there are 0 added.
If I try to add them, click the plus button and go through the list, I can't seem to locate a few key frameworks (AppKit, Cocoa, Quartz, QTKit, and OpenGL
Any ideas.
YueWu1
Hmm... That's a little strange. Have you changed any code behind?
I would suggest to unzip a new OfflineEditingSample and deploy again. You shouldn't have to worry about those framework, those are only needed when creating a new project from scratch.
GISProgrammer
New Contributor III
No code behind has been changed.  I downloaded the zip file and tried from there with the same results.  If I plug in my iPadAir and deploy it to that the screen is all white (not black).  What device or simulator are you deploying to?
YueWu1
I deploy on iPhone5, simulator for iPhone and iPad. Here is the screenshot I just took from my simulator for iPad. I suspect might related to network issue, can you try to hit the url directly? http://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/Wildfire/FeatureServer
Are you using any proxy setting or any firewall that block the access?
GISProgrammer
New Contributor III
I can hit the service end point and query it from the rest.  I can view it on ArcGIS.com and add new features.  I don't think it is access because I can edit the points in the simulator, my phone (5s), or my Air.  I can change attributes, move location of points, and add attachments.  The only thing that doesn't work is adding a new feature.  I click the plus button and all goes black and the app is stuck.
Not really sure at this point.
GISProgrammer
New Contributor III
Here's what it looks like on my Air:
Here's what it looks like if I click the add button...much worst on the iPhone or simulator
Here's another image of editing a existing feature, which works:
GISProgrammer
New Contributor III
Michael, thanks for the reply that is what I was thinking but it sounded like Yue Wu also just download the new sample and it works for him...I didn't change a thing..download the zip twice and forked it once..same problem.
Just a few more notes to maybe shed some light on something...maybe you can tell me if this looks corrects..should the ArcGIS.bundle be red?
Here's the screen shot of the 5s simulator:
Once again the app launches looks great responds great
Except when I hit the plus button:  Goes black.
If someone wouldn't mind downloading the newest sample and letting me know that would be super cool.
The deployment target is 6.0 universal (phone and pad) 6.0 shouldn't matter right?
Thanks
YueWu1
Hi there,
I think I figure out your problem. The reason is because you using iOS8 to test the application.(see the windows title of the simulator) Currently, ArcGIS Runtime SDK for iOS not officially support iOS8. That's why you may encounter some unknown issue. You should change the deployment target to either 7.0 or 7.1 as the screenshot I took to you.
Screen Shot 2014-07-23 at 5.39.50 PM.png  Screen Shot 2014-07-23 at 5.46.26 PM.png
Like I said in the previous post, make sure using XCode 5 and iOS 7 SDK. It's on the System requirements—ArcGIS Runtime SDK for iOS
