Populate AGSGDBFeatureServiceTable without adding a layer
3875
02-10-2015 02:17 PM
KyleDunaway
New Contributor III
If i create a AGSGDBFeatureServiceTable from a rest service, it doesnt populate until I create a AGSFeatureTableLayer and add the layer to the map.
Can i populate the AGSGDBFeatureServiceTable without adding the layer to the map?
Thanks
Edit:  I cant even query a agsgdbfeatureservicetable, i always get zero results.
Tags (1)
Nicholas-Furness
Unfortunately no, currently the AGSGDBFeatureServiceTable is meant to be used with a layer.
I will see if we can make the documentation clearer on this.
