Problem installing Quartz SDK Beta 3 using CocoaPods
1790
6
10-10-2016 12:08 AM
ShiminCai
Occasional Contributor III
Hi All,
I'm following the instructions of the "Get started: Install and setup" in the online documentation to install Quartz SDK Beta 3 using CocoaPods and encountered this problem:
garrytoshiba:FCMapApp2 shiminc$ pod install
Analyzing dependencies
[!] Unable to satisfy the following requirements:
- `ArcGIS-Runtime-SDK-iOS (= 100.0-beta3)` required by `Podfile`
None of your spec sources contain a spec satisfying the dependency: `ArcGIS-Runtime-SDK-iOS (= 100.0-beta3)`.
You have either:
 * out-of-date source repos which you can update with `pod repo update`.
 * mistyped the name or version.
 * not added the source repo that hosts the Podspec to your Podfile.
Note: as of CocoaPods 1.0, `pod repo update` does not happen on `pod install` by default.
My podfile looks like this:
# Uncomment this line to define a global platform for your project
source 'https://github.com/CocoaPods/Specs.git'
platform :ios, '8.0'
  target 'FCMapApp' do
  # comment this line if you're not using Swift and don't want to use dynamic frameworks'
  use_frameworks!
  pod 'Dropbox-iOS-SDK'
  pod 'SVProgressHUD', :git => 'https://github.com/SVProgressHUD/SVProgressHUD.git'
  pod 'ArcGIS-Runtime-SDK-iOS', '100.0-beta3'
  pod 'IQKeyboardManagerSwift'
  target 'FCMapAppTests' do
  inherit! :search_paths
  # Pods for testing
  end
end
Actually I'm trying to upgrade a workspace that works fine with the SDK 10.2.5 by changing the line "pod 'ArcGIS-Runtime-SDK-iOS'" to "pod 'ArcGIS-Runtime-SDK-iOS''100.0-beta3'".
Can anybody shed any light on what I'm doing wrong please?
Many thanks.
Shimin
LinnartBaeker
New Contributor II
Did you try:
pod repo update
As suggested in the error message? I installed the Beta SDK via CocoaPods without any problems.
DanPatterson_Retired
Install and set up—ArcGIS Runtime SDK for iOS (Quartz Beta) | ArcGIS for Developers from there it leads to
System requirements—ArcGIS Runtime SDK for iOS (Quartz Beta) | ArcGIS for Developers with comments about the supported iOS version.  there seems to be a difference in developing and using. I assume your requirements are met?
ShiminCai
Thanks Dan for your reply. I revisited those documents you listed. My Macbook has Xcode 7.3, OS XEI Capitan 10.11.6 and 2.6 GHz Intel Core i7 processor which should meet the system requirements for developing with the Quartz SDK.
ShiminCai
I created two identical fresh Xcode projects and tried to install pod 'ArcGIS-Runtime-SDK-iOS' and pod 'ArcGIS-Runtime-SDK-iOS', '100.0-beta3' in the projects separately.
With the pod 'ArcGIS-Runtime-SDK-iOS', the pod install went ok and installed 10.2.5:
Last login: Tue Oct 11 13:27:28 on ttys000
garrytoshiba:~ shiminc$ cd Projects/Test/CocoaPodsTest
garrytoshiba:CocoaPodsTest shiminc$ pod install
Downloading dependencies
Using ArcGIS-Runtime-SDK-iOS (10.2.5)
Generating Pods project
Integrating client project
Sending stats
Pod installation complete! There is 1 dependency from the Podfile and 1 total
pod installed.
But the install of pod 'ArcGIS-Runtime-SDK-iOS', '100.0-beta3' failed with the save error as before:
Last login: Tue Oct 11 13:44:25 on ttys000
garrytoshiba:~ shiminc$ cd Projects/Test/CocoaPodsTest1
garrytoshiba:CocoaPodsTest1 shiminc$ pod install
You have either:
I also did a search in the https://cocoapods.org and only found the SDK 10.2.5 and couldn't find the version 100.0-beta3. So my question is: does the beta version 100.0-beta3 exist at all? Or what should I do to be able to install the  Quartz beta3 of the ArcGIS Runtime SDK using CocoaPods?
Any help is much appreciated.
Shimin
LinnartBaeker
New Contributor II
Did you try:
pod repo update
ShiminCai
Yes I did. Today tried again and got the same error.
garrytoshiba:FCMapApp2 shiminc$ pod repo update
Updating spec repo `master`
Performing a deep fetch of the `master` specs repo to improve future performance
[!] /usr/bin/git fetch --unshallow
error: RPC failed; result=56, HTTP code = 200
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
It took very long to get the error...
ShiminCai
With a faster Internet (20 mbps), still no luck with the 'pod repo update':
Shimins-MBP:FCMapApp2 shiminc$ pod repo update
  $ /usr/bin/git pull --ff-only
  fatal: unable to access 'https://github.com/CocoaPods/Specs.git/': transfer closed with outstanding read data remaining
[!] CocoaPods was not able to update the `master` repo. If this is an unexpected issue and persists you can inspect it running `pod repo update --verbose`
However, with the  'pod update', successfully installed the beta idk:
Shimins-MBP:FCMapApp2 shiminc$ pod update
Update all pods
Updating local specs repositories
CocoaPods 1.1.0.rc.3 is available.
To update use: `sudo gem install cocoapods --pre`
[!] This is a test version we'd love you to try.
For more information, see https://blog.cocoapods.org and the CHANGELOG for this version at https://github.com/CocoaPods/CocoaPods/releases/tag/1.1.0.rc.3
Pre-downloading: `SVProgressHUD` from `https://github.com/SVProgressHUD/SVProgressHUD.git`
Installing ArcGIS-Runtime-SDK-iOS 100.0-beta3 (was 10.2.5)
Using Dropbox-iOS-SDK (1.3.13)
Installing IQKeyboardManagerSwift 4.0.6 (was 4.0.2)
Installing SVProgressHUD 2.0.3 (was 2.0.3)
Sending stats
Pod installation complete! There are 4 dependencies from the Podfile and 4 total
pods installed.
Thank you for your help. Much appreciated.
Cheers,
Shimin
