Is your feature layer a base layer (first layer in the map view)? If yes, you should just add one tiled or dynamic layer as base layer and make feature layer as operational layer.
Regards,
Nimesh
UIView<AGSLayerView> *flView = [self.mapView addMapLayer:self.featureLayer withName:@"Feature Layer"]; flView.alpha = 0.5;
Okay..let's look at two issues one by one.
1. Does adding feature layers on TOP of tiled layer resolves the scale dependent issue?
2. If yes, you should set the transparency on the feature layer view to resolve tiled layer label display issue. Here is the code...UIView<AGSLayerView> *flView = [self.mapView addMapLayer:self.featureLayer withName:@"Feature Layer"]; flView.alpha = 0.5;
Regards,
Nimesh
