Unrecognized leading character
2336
7
10-10-2011 09:10 AM
MiriEshel
New Contributor III
I'm using the new iOS API (version 2.0.1).
I'me trying to operate IdentifyTask on visible layers in : http://www3.emap.co.il/ArcGIS/rest/services/Clients/NetanyaWater/MapServer
The identify fails and I get the error : NSLocalizedDescription=Unrecognized leading character.
When I address other services like : http://www3.emap.co.il/ArcGIS/rest/services/Clients/batyam/MapServer, it works fine.
Does anyone know why?
Miri
NimeshJarecha
I tested the URL mentioned by you for identify task and I see NO error. Could you please provide a sample application to test?
Regards,
Nimesh
MiriEshel
New Contributor III
Nimesh,
Sorry. I had an error in my code. I just thought, because of the error message, that the problem is in the service and not in the code.
Sorry again...
Miri
NimeshJarecha
No problem!
Regards,
Nimesh
Sunitapatil
I have the same problem Getting the error
" Error Domain=org.brautaset.JSON.ErrorDomain Code=3 "Unrecognised leading character" UserInfo=0x602a340 {NSLocalizedDescription=Unrecognised leading character} "
NimeshJarecha
What you are trying to do? When this error happens? Post code to reproduce the error.
Regards,
Nimesh
Sunitapatil
I am trying to access the services from vpn server. When i am logged in to vpn server and run iphone application I got this error
Error msg:
Error Domain=org.brautaset.JSON.ErrorDomain Code=3 "Unrecognised leading character" UserInfo=0x6312830 {NSLocalizedDescription=Unrecognised leading character}
NimeshJarecha
You are getting error because from your iPhone, service (from your ArcGIS Server) is not accessible. Please make sure that on iPhone device browser you are able to access the service (REST end point) after connecting to the VPN.
Regards,
Nimesh
