using System.Windows; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Symbols; using System.Windows.Media; using ESRI.ArcGIS.Client.Geometry; using System; using System.Windows.Threading; namespace SmoothAnimation { public partial class MainWindow : Window { GraphicsLayer _gl; private DateTime animateStartTime; private DispatcherTimer animationTimer; private int animationDuration = 5000; SimpleMarkerSymbol defaultSymbol; SimpleMarkerSymbol animatingSymbol; public MainWindow() { InitializeComponent(); _gl = new GraphicsLayer(); MyMap.Layers.Add(_gl); } private void MyMap_MouseClick(object sender, Map.MouseEventArgs e) { if (defaultSymbol == null) { defaultSymbol = new SimpleMarkerSymbol() { Color = Brushes.Red, Size = 12, Style = SimpleMarkerSymbol.SimpleMarkerStyle.Circle }; } if (animatingSymbol == null) { animatingSymbol = new SimpleMarkerSymbol() { Color = Brushes.Blue, Size = 12, Style = SimpleMarkerSymbol.SimpleMarkerStyle.Circle }; } if (_gl.Graphics.Count == 3) _gl.Graphics.Clear(); if (_gl.Graphics.Count == 2) _gl.Graphics.Remove(_gl.Graphics[0]); _gl.Graphics.Add(new Graphic() { Symbol = defaultSymbol, Geometry = e.MapPoint }); } private void AnimateButton_Click(object sender, RoutedEventArgs e) { MapPoint startPoint = _gl.Graphics[0].Geometry as MapPoint; MapPoint finishPoint = _gl.Graphics[1].Geometry as MapPoint; MapPoint animatingPoint = startPoint; _gl.Graphics.Add(new Graphic() { Geometry = animatingPoint,Symbol = animatingSymbol }); animationTimer= new DispatcherTimer(); animationTimer.Interval = TimeSpan.FromMilliseconds(33); animateStartTime = DateTime.Now; animationTimer.Tick += (s, ex) => { double fraction = (DateTime.Now - animateStartTime).TotalMilliseconds / animationDuration; fraction = QuinticEasingInOut(fraction, 0, 1, 1); var x = (finishPoint.X - startPoint.X) * fraction + startPoint.X; var y = (finishPoint.Y - startPoint.Y) * fraction + startPoint.Y; animatingPoint.MoveTo(x, y); }; animationTimer.Start(); } public double QuinticEasingInOut(double t, double b, double c, double d) { t /= d / 2; if (t < 1) return c / 2 * t * t * t * t * t + b; t -= 2; return c / 2 * (t * t * t * t * t + 2) + b; } } }
<Window x:Class="SmoothAnimation.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" Title="MainWindow" Height="350" Width="525"> <Grid> <esri:Map x:Name="MyMap" UseAcceleratedDisplay="True" MouseClick="MyMap_MouseClick"> <esri:ArcGISTiledMapServiceLayer ID="World Topo Map" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> </esri:Map> <Button Content="Animate" x:Name="AnimateButton" VerticalAlignment="Top" HorizontalAlignment="Center" Margin="10" Click="AnimateButton_Click"> </Button> </Grid> </Window>
