Drill-down Geocoder
3067
22
08-15-2011 06:57 AM
MichaelErlich
New Contributor II
We are trying to create a drill-drown geo-coder similar to what see in tom-tom/garmin systems in your vehicle where you select state, then select city, then select street name.  Using the 'Find Local Layer' with a little re-tooling, we have been able to search for attributes in the map meta-data.  However, we have not been able to add a filter with the search text.  In other words, we can search for a street by the first few letters entered by the user, but have not found a way to also add in the city/state criteria to the search.  Are there other ways to the use the FindTask to provide multiple search criteria rather than just setting the 'SearchText' field in the FindParameters, is there an extended version of the FindParameters that we are missing, or are we way off base and possibly you have some other suggestions on how we can achieve the same searching capability?
Mike
KerrieScholefield
Update...  The locator will not work for providing a list of street names when only a couple of characters are provided.
For example: 'Will', 'Willo' return no results.  While, 'Willow' or 'Willow Rd' will return results for 'Willow Rd'.
Are you using the QueryTask for your locator?
Using a query in the query task of: (L_ORDER08 = 'CO123' or R_ORDER08 = 'CO123') and UFULLNAME LIKE '%ERIE P%'  gives a timeout exception when searching across file consisting of 10 states.  All three of those fields have been indexed.
So, any suggestions, or is the runtime not capable of performing this task?
The runtime is capable of performing the valid OR SQL query.
query.Where = "AREANAME = 'Hilo' OR AREANAME = 'Troy'";
The runtime is also capable of performing the  LIKE with % wildcard SQL query.
query.Where = "AREANAME LIKE '%la%'";
What type of file are you searching?
Cheers
Kerrie
MichaelErlich
New Contributor II
Yes we are using the QueryTask, but it keeps timing out.  The data we are using consists of 13 U.S. states using a geo database in a mappack.
Can a locator lookup by partial text?  I.e. If I enter 'M', return everything with 'M...'.  If I enter 'Mi', return everything with 'Mi...'.  So far we have not been able to get the locator to work unless the search name is near complete.  Also, when looking at the REST call for the locator, there are a bunch of properties for specifying the sensitivity settings, but I don't see any way to set those settings with the locator API.  Am I missing something there?  Also, to create a locator in arcmap, is there any way to specify the default sensitivity settings?
Update: double clicking on the apk to edit the sensitivity settings didn't have any effect.  Uncompressing the apk, and changing the settings in the .loc file, then recompressing had no effect as well and it reverted back to its original default settings.
MichaelErlich
New Contributor II
Found out about the address locator properties to edit the settings which do get used (my hack method must have missed something that forced the changes to be ignored).  However, even after changing the settings, it doesn't produce any candidates if I only type the first few characters.  Is there anyway for this type of search to return candidates?
KerrieScholefield
I am unable to reproduce the time out issue with the QueryTask with a US states dataset. Is it possible for you to send a sample application and data with which I could try to reproduce the issue?
No, the locator cannot lookup by partial text as our current technology and design does not support the "drill-down" search. The spelling sensitivity setting specifies the variation the address locator allows when it searches for likely candidates but it will not perform the partial text search you describe above. If you enter 'Mark' it will return similar spellings as match candidates such as �??Marcel�?? but not all the words containing �??Mark�??.
The sensitivity settings are not set through the API but as you discovered by double-clicking the address locator in the workspace to display the Address Locator Properties dialog box and editing the sensitivity settings. To use these changes in the .apk you will need to rebuild the locator and then republish to .apk. This can be done in ArcCatalog by the steps below:
  • To change the spelling sensitivity - right click on the locator > Properties > Geocoding options and change the spelling sensitivity (maybe try the value of 1 to test) > OK
  • To keep the settings -  right click the locator > Rebuild
  • To get the .apk to reflect these changes - right click the locator > Share As > Locator Package
It is worth remembering that the spelling sensitivity does not affect the match score of each candidate; it only controls how many candidates the address locator considers. The address locator computes the match score of each candidate and ranks the candidates by score.
It might also be worth checking what the minimum candidate score and minimum match score are in the locator properties as these also filter the results whereby those potential matches that have a score lower than the minimum candidate score are removed from the potential match list and an address below the minimum match score is considered to have no match.
Cheers
Kerrie
JamesMcElroy
Hi Kerrie,
Either Mike B or Ralf should already have the data, as it's the same stuff we've been using for all our other issues.  It's called MergedWest.mpk.
I don't have a sample app for you, but just using the QueryTask against the Streets layer of that data with a where clause like "NAME like '%SEARCH_STRING%'".  I tried searching for a street called "E Northern Lights Blvd" starting letter by letter.  So first it was '%N%', then it was '%No%' (we've since added a UNAME column with the names upper-cased, but you see the same behavior either way.  Where it started timing out for me was about '%Norther%'.  Any letters more than about 5 and it returned timeout exceptions.  That layer has about 9,000,000 records in it, and we've also added indexes to the columns we are searching.
I'm also uploading the map pack with the UName column and indexes to our FTP site, you can get the details from Ralf or Mike B.  It's called MergedWestUC.mpk.  It's just over a gig, so it'll probably take a bit to complete.  If you're still unable to reproduce then I'll put together a simple sample that replicates what we're doing for you.
James
If you still can't
MichaelErlich
New Contributor II
Kerrie,
If you can provide your email, we can provide the ftp login information so that you can get the files that we are using for testing.
Regards,
mike
KerrieScholefield
Kerrie,
Regards,
mike
I am in the process of downloading the data from your FTP site now and will test it once this is complete.
Cheers,
Kerrie
KerrieScholefield
I performed the query "UNAME LIKE '%NORTHER%'"; against the UNAME column of the Streets layer in MergedWestUC.mpk successfully and could not reproduce the issue you are experiencing. Where are you accessing your .mpk from? Below is the csharp code behind I am using in my test application - please let me know if/how your code differs:
using System.Windows;
using ESRI.ArcGIS.Client.Local;
using ESRI.ArcGIS.Client.Tasks;
namespace QueryTest
  public partial class MainWindow : Window
    public MainWindow()
      InitializeComponent();
      LocalMapService mapService = new LocalMapService()
        Path = @"C:\forums\zoll\MergedWestUC.mpk",
        MaxRecords = 5000000
      mapService.StartAsync();
      mapService.StartCompleted += (s1, e1) =>
        if (mapService.Error == null)
          query(mapService);
    private void query(LocalMapService ms)
      QueryTask queryTask = new QueryTask();
      queryTask.Url = ms.UrlMapService + "/4";
      queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
      queryTask.Failed += QueryTask_Failed;
      Query query = new ESRI.ArcGIS.Client.Tasks.Query();
      query.OutFields.AddRange(new string[] { "UNAME" });
      query.ReturnGeometry = true;
      query.Where = "UNAME LIKE '%NORTHERN%'";
      queryTask.ExecuteAsync(query);
    private void QueryTask_Failed(object sender, TaskFailedEventArgs args)
      MessageBox.Show("Query failed: " + args.Error);
    private void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
      FeatureSet featureSet = args.FeatureSet;
      if (featureSet == null || featureSet.Features.Count < 1)
        MessageBox.Show("No features retured from query");
        return;
Cheers,
Kerrie
JamesMcElroy
We're pretty much doing that, but I'm not setting the
lines.  Does not setting the OutFields parameter affect the performance of the execution?
We're also not setting the MaxRecords property of the service.
James
JamesMcElroy
Hi Kerrie,
I created a small test app to see if I could reproduce your results.  When I tried with your code verbatim it didn't work at all.  This is probably because, as I said earlier in the thread, our app runs a query on some filter text that the user is typing in.  So it starts with "N", then "No", then "Nor", etc...  With the MaxRecords set to 5000000 searching "N" takes about 20 minutes, pushes memory usage up to over 1GB, and then the process just dies.
Once I removed the MaxRecords property I was able to get results since it was limited to 1000.  I wasn't able to get timeouts, but I can only assume that this was due to the fact that, in our main application, the querying is being done on a background worker thread and then sending the results back up to the UI via eventing.  I've enclosed the amount of time the queries took, both synchronous as well as asynchronous, (I'm .ToUpper'ing the filter before actually feeding it to the query task).  As you can see there is a serious degradation in performance between 5 and 6 characters, and then again between 9 and 10 characters.
I'm guessing that the threading timeouts are due to the query task being run on a background thread, but these performance numbers are still pretty tough.
Synchronous
"N" - 0.216s
"No" - 0.531s
"Nor" - 1.51s
"Nort" - 3.018s
"North" - 3.457s
"Northe" - 12.565s
"Norther" - 12.751s
"Northern" - 12.511s
"Northern " - 12.492s
"Northern L" - 71.665s
"Northern Li" - 64.156s
"Northern Lig" - 64.527s
Asynchronous
"N" - 0.517s
"No" - 0.615s
"Nor" - 1.666s
"Nort" - 3.304s
"North" - 3.776s
"Northe" - 14.143s
"Norther" - 13.362s
"Northern" - 13.219s
"Northern " - 13.160s
"Northern L" - 69.969s
"Northern Li" - 65.064s
"Northern Lig" - 65.164s
