OK, I've had success generating map packages by building a model, and it works well. What I'm now having a hard time with is generating tile packages.
Using server tools->Caching I can generate a Tiling Scheme, no problem. But if I try to Create/Export into a tile package, it always has an input service as required input, which I don't have.
If I use File->Share As->Tile Package then I have the option of either a Tiling Scheme or a Map service.
So is it possible to do this as a model?
Andrew Purkis
