We're seeing some concerning performance issues related to routing using local data via the GeoProcessing tools. Thanks to Ralf we were able to get a functional gp model to create a gpk for routing. I tried creating two packs, one using just the data for Arvada, CO, and one using the data for 10 states (Western US + Alaska).
Inside ArcMap creating a route using Arvada's data took 3 seconds. Using the gpk via Runtime took 4 seconds (this is for a very short route, maybe 2 miles total). This is a long time for a short route.
I saw the same results using the 10-state pack as the Arvada pack. That is good because it means performance is the same irregardless of data size after startup.
After that it seems to be almost a linear progression of distance to time. A route from Longmont, CO to Arvada, CO took 11 seconds to build, and a route from Laramie, WY to Arvada, CO took 17 seconds to build.
This is much slower than the routing engine in MapObjects, and even Bing web services takes less than a second for the same route.
It seems like there are serious performance concerns for doing routing via the GeoProcessing tasks.
James
