How to connect Editor widget to local feature layer in group layer
943
12-04-2013 12:15 AM
IanBates
New Contributor II
Hi
I am using the WPF runtime sdk (10.2) and creating a ArcGISLocalFeatureLayer as follows:
            ArcGISLocalFeatureLayer arcGISLocalFeatureLayer = new ArcGISLocalFeatureLayer
                Service = localFeatureService,
                ID = layerId,
                LayerName = layerName,
                DisableClientCaching = true,
                OutFields = new OutFields() { "*" },
                Editable = true,
                AutoSave = false,
                ValidateEdits = true,
                Mode= FeatureLayer.QueryMode.Snapshot
Later I connect the Editor Widget by setting the LayerIDs via the VM binding where layerIds is a string array of the ids of my layer as defined above.
EditLayerIds = new ObservableCollection<string>(layerIds);
and in the xaml:
  <esri:EditorWidget x:Name="MyEditorWidget"
Map="{Binding ElementName=myMap}"
              Width="300"
  AutoSelect="False"
  ShowAttributesOnAdd="True"
  LayerIDs="{Binding EditLayerIds}"
  GeometryServiceUrl="{Binding GeometryServiceUrl}"     />
However making the feature layers child layers of a Group Layer prevents the EditorWidget initializing. However all is fine if the Feature layers are placed directly as a map layer.
The editable feature layers are otherwise displayed normally when hosted withing the Group Layer.
Is there something more I need to do to connect the EditorWidget to a feature layer within a group layer? I tried
{Group LayerId}/{Feature LayerId} as the layerid - but that makes no difference. Alternatively not setting (binding) the LayerIDs (which is supposed to connect to all feature layers) also does not work.
Regards,
Ian
MichaelBranscomb
Esri Frequent Contributor
I've reproduced the issue - we'll investigate.
Cheers
Mike
IanBates
New Contributor II
Cheers
Mike
Thanks for looking into this - we have a product release on Monday are you able to supply us with a workaround to this issue quickly?
MichaelBranscomb
I'll check with the team and get back to you as soon as I can. The source code for the EditorWidget is published on GitHub (https://github.com/Esri/arcgis-toolkit-sl-wpf), which means potentially you could look at the EditorWidget source and make your own fix then rebuild.
Cheers
Mike
MichaelBranscomb
Is it possible it's just a binding issue? - e.g. string[] versus ObservableCollection<string>
Cheers
Mike
IanBates
New Contributor II
Thanks for pointing that out. We are now using the Editor class directly instead of the widget so I will retest the issue on Monday
