Hi
I am using the WPF runtime sdk (10.2) and creating a ArcGISLocalFeatureLayer as follows:
ArcGISLocalFeatureLayer arcGISLocalFeatureLayer = new ArcGISLocalFeatureLayer
Service = localFeatureService,
ID = layerId,
LayerName = layerName,
DisableClientCaching = true,
OutFields = new OutFields() { "*" },
Editable = true,
AutoSave = false,
ValidateEdits = true,
Mode= FeatureLayer.QueryMode.Snapshot
Later I connect the Editor Widget by setting the LayerIDs via the VM binding where layerIds is a string array of the ids of my layer as defined above.
EditLayerIds = new ObservableCollection<string>(layerIds);
and in the xaml:
<esri:EditorWidget x:Name="MyEditorWidget"
Map="{Binding ElementName=myMap}"
Width="300"
AutoSelect="False"
ShowAttributesOnAdd="True"
LayerIDs="{Binding EditLayerIds}"
GeometryServiceUrl="{Binding GeometryServiceUrl}" />
However making the feature layers child layers of a Group Layer prevents the EditorWidget initializing. However all is fine if the Feature layers are placed directly as a map layer.
The editable feature layers are otherwise displayed normally when hosted withing the Group Layer.
Is there something more I need to do to connect the EditorWidget to a feature layer within a group layer? I tried
{Group LayerId}/{Feature LayerId} as the layerid - but that makes no difference. Alternatively not setting (binding) the LayerIDs (which is supposed to connect to all feature layers) also does not work.
Regards,
Ian
