Loading raster images into accelerated layers.
5160
16
10-04-2012 11:27 AM
AaronMorrisett
I am having issues finding a suitable method of loading a rastered geotiff file into the accelerated layers collection.  My current method that works fine is to load the image into a ElementLayer as follows.
var image = new BitmapImage(new Uri(filePath));
 var newLayer = new ElementLayer();
 var rect = new Rectangle();
 rect.SetValue(ESRI.ArcGIS.Client.ElementLayer.EnvelopeProperty, convertedEnvelope);
 rect.Fill = new ImageBrush(image);
 newLayer.Children.Add(rect);
_esriMap.Layers.Add(newLayer);
This method works fine except I have a accelerated layer collection that is rendering points from GPS readings that needs to be plotted on top of the rastered image.  The only work around I can find is to change the opacity of the Element Layer in order to at least show the points behind the layer.  This is a prefered method, I would like to be able to add the georeferenced image to a layer within my acceleratedLayers collection so I could set the layer order.
If I have not explained my situation well enough let me know and I'll attempt to reword it.
Regards,
    Aaron
mohscorpion
i have top left and bottom right , latitude and longitude . can i envelope and show it?
mohscorpion
is there any tool in wpf sdk that i can use to convert normal image files to georeferenced ones?
MichaelBranscomb
Esri Frequent Contributor
Hi,..
If you have the coordinates of the corners, can you create world file? World files for raster datasets—Help | ArcGIS for Desktop
Cheers
mohscorpion
i prefer not to create additional files , since i am a programmer not a gis expert.
mohscorpion
is there already written formulas based on raster size and lat/long of corners?
MichaelBranscomb
This is the basic formula:
It's just a text file based on the file extension of the image e.g. tfw, pgw, etc. Google will help there.
The contents of the file are 6 lines:
5.000000000000 (size of pixel in x direction)
0.000000000000 (rotation term for row)
0.000000000000 (rotation term for column)
-5.000000000000 (size of pixel in y direction)
492169.690845528910 (x coordinate of centre of upper left pixel in map units)
5426523.318065105000 (y coordinate of centre of upper left pixel in map units)
Cheers
Mike
mohscorpion
thank you very much indeed, it worked!!
