The "WrapAround" property says that it only supports WGS84 projections. The layers in my map package have GCS_WGS_1984 as the coordinate system. I'm not sure if that's the same or not. But when I set the property to true and add my LocalDynamicMapServiceLayer to the map control I checked the "WrapAroundIsActive" property and it was false, and the "SpatialProjection" of the map object was null. Since it's a read-only property, how should I set the SpatialProject to the WGS84?
James
