I'm wondering if it is possible to have multiple attributes show up in the legend? I have a layer with letter codes in one column and the written out description in another column in the attribute table. Is it possible to both both as one label in my map legend without have to manually type them in?
If you symbolize the feature class by letter code and description (under symbology tab in layer attributes -> categories -> unique values, many fields), then the legend entry will be "letter code, description".
Thanks, I knew it should be in symbology somewhere!
