I am trying to transfer citizen problem reports into workforce. I'm using the steps provided by
Create Workforce assignments - Crowdsource Reporter | ArcGIS Solutions
however have come up with some road blocks.
It says in step three to
"Open the assignments layer that was created as part of the Workforce project and choose the Assignment Type field."
in ArcPro, however this option is not available, most likely because when workforce creates this field it chooses the GUID data type. Therefore, I can't complete this step/change any domains in my source reporter table as it requests.
I tried changing the data types to strings by deleting and re-adding the assignment types field, but doing this seems to disconnect the fields from the workforce interface, so I have decided to start over.
Not wanting to change any fields and still having the step 3 issue, I decided to run the code "as-is" without changing any of the domains (steps 7-9)
Now, when I run the code, the source layer updates the status, as I have instructed it to do, but nothing is transferred to workforce. I added the code in hopes that I am not seeing a mistake.
Has anyone else found a work-around for step 3, or have had a problem with the create workforce assignments step?
