change range of raster
3419
6
09-18-2016 09:08 PM
LanoYado
Hi, I have a raster layer that has values between 0.5 to 2.0. I want to change (narrow) the range of its values to be between [0.95 1.05]. Every cell value of the layer of course changes accordingly.  Any tool or way in ArcGIS to do that?
Thanks in advance
DanPatterson_Retired
don't know if there is a builtin but there are examples of rescaling data using python on the web
ie python - Convert a number range to another range, maintaining ratio - Stack Overflow
which is in theory could be implemented using The transformation functions available for Rescale by Function—Help | ArcGIS for Desktop using a linear scale function Rescale by Function—Help | ArcGIS for Desktop
but I haven't tried it
NeilAyres
MVP Alum
I had never seen that rescale by function tool. Very cool.Thanks Dan
Neil... There is a whole load of other functions in that associated list The transformation functions  looking for a purpose...
XanderBakker
Esri Esteemed Contributor
You could use the raster calculator and apply something like:
((RasterValue - 0.5) / (2.0 - 0.5)) * (1.05 - 0.95) + 0.95
... to stretch the values linearly.
However I like the option provided by Dan_Patterson  better.
LanoYado
Thanks all. Very helpful.
I marked your question assumed answered, if that is alright, since you didn't select one
