Also having problems with CON in raster calculator. The quotes and percent signs seem to get added when I drag a lyer listed above the expression. Could it be the "dot" syntax
CON("%hor_vis_rg%".count >= 23, 1)
So then I tried the CON function instead of Raster Calculator, with the SQL expression "Count" >= 310, and got the same Error.
