Cost Path Tool Usage Help
2606
07-23-2011 05:33 AM
--7
I'm have the following data:
  • Raster layer, cells have 1 of 2 values that represent either an obstacle or non-obstacle
  • Layer with single point feature (source)
  • Layer with single point feature (destination)
I'm trying to find the shortest path between the source and destination points while avoiding obstacles.  I tried creating a cost distance and cost backlink using the raster and the source point feature in ArcMap but the rasters I got had cells with 0 values only.
Am I doing something wrong? Should I be using the cost path tool for this?
JohnPorter
New Contributor II
Two items that might cause the problem you encountered.
1) make sure that even your impassable elements have a valid (but very, very, high) impedance/cost value, not NODATA
2) your cost-raster should be in GRID format. I've had many problems with other raster formats (e.g., TIFF) not working properly in analyses.
Hope that helps!
HelenGoodchild
New Contributor III
Thanks very much for this - I was having the exact same problem, then you made me realise I had an impossible path as there were too many areas of NoData in my friction map.
Many thanks!
