Creating raster out of points
4104
08-17-2011 12:01 AM
JoostBrama
I'm quite a newbee in this forum, but I hope someone can help me with my (I think) little problem.
I'm trying to convert a point feature class to a raster.
The point feature class contains 13 points with different values in the attribute table.
When I use the Point to Raster tool (with value field), I just create one cell block on the place of the point (it looks like there are 13 cell blocks in the Raster).
Now a cell contains the value of the point attribute, but the cell next to that one has a value of 0. That's not what I want, I want it to slowly become less.
For example, the point has a value of 200. After the point to raster tool, the cell in the raster has got a value of 200. A cell next to this one has a value of 0, but I want this value to be (for example) 195.
How can i do that?
I hope someone can help me.
(I use ArcGIS 9.3 with the Spatial Analyst & Data Interoperability Extensions)
Joost
JeffreySwain
What you are looking to do sounds like interpolation.  I would recommend taking a look at the different interpolation tools, which will fill in the gaps between the points.  Or perhaps the point density tool will work, depending on your analysis.
JoostBrama
Thanks, that's what I was looking for.
Next problem is how I get a larger extent then just the 4 points with the largest and lowest X & Y.
Can I put in a border or something?
DanPatterson_Retired
All tools in Arctoolbox have the often-overlooked "Environments" tab, this is where you should be setting cell size, analysis extents etc etc. prior to clicking any OK button
JoostBrama
Dan & Jeff,
I've worked it out. Thanks for your help.
