I’ve not been able to resolve an issue with a Model performing either a Polygon to Raster or Feature to Raster conversion. It just hangs, despite restarts, rebuilding the model, long waits, etc. It seems stuck in a loop and haven’t found a support case or article dealing with this. Task Manager shows process cycling between the same Memory and CPU metrics which is why I think it’s in a loop. The feature is a small subset of USDA Soil Map Unit features with a Hydro Group Number (long data type, not the alpha code) for the raster pixel values. There are only 154 polygons in the feature set and it's for only 1 HUC-12 catchment/basin area. All values are non-null and range from 1-4. It should run in no time. Thoughts?
Executing (Feature to Raster): FeatureToRaster "Site Analysis\08_Soil\soilmu_a_aoi" HYDGRP_NUM "C:\Users\jamie\Documents\Education\GIS\501-Capstone Project\Scratch.gdb\FtoRTest" "C:\Users\jamie\Documents\Education\GIS\501-Capstone Project\CapstoneProject.gdb\ContextDEM"
Start Time: Thu Aug 20 15:49:05 2020
Cancelled function
Cancelled function
(Feature to Raster) aborted by User.
Failed at Thu Aug 20 16:38:43 2020 (Elapsed Time: 49 minutes 37 seconds)
