Flow Concentration
4194
7
02-05-2015 07:29 AM
NazmulAhasan
New Contributor II
HI,
I have a raster layer of a roof (imported from Sketchup then converted to raster by Multipatch tool). I want to find out flow concentration on the roof if rain is falling vertically on the roof. Can you tell the process to do this.
Thanks in advance
XanderBakker
Esri Esteemed Contributor
It is actually called Flow Accumulation (part of Spatial Analyst). The Help can be found here: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
You should use a cell size small enough to simulate the accumulation. What is the extent of the roof and the cell size you used when converting from the multipatch?
XanderBakker
NazmulAhasan
New Contributor II
I used a larger cell size 0.5 x 0.5 thought it will help to reduce calculation time. But the raster looked coarse. what cell size will be good for this case anyway?
XanderBakker
This depends on the detail (precision) you are trying to obtain and the precision of the input data (combined with the extent of your roof). If you provide some more info then I can advise you better...
NazmulAhasan
New Contributor II
the roof is approx~23 ft in long direction and ~12ft in width.
after all thank's for your effort.
XanderBakker
If the roof is that "small" (not an industrial building" or something very large) you could use a resolution that is very high (a cell size much smaller than 0.5m).
I have had some problems in the past with this funcionality when using a cell size smaller than 1 (or using a decimal cell size). At that time I didn't have the time to investigate why and I don't know if the problem is still present in the current version. Since your roof has a small surface, using a small cell size will not resulting in long processing times.
What precision do you need when it comes to the resulting accumulated flow? Interesting case.
NazmulAhasan
New Contributor II
actually there was no precision boundary. I was asked to produced a 3D plot of flow concentration of the roof. I have this by converting flow accumulation raster to ASCII format than importing to MATLAB asd plotting as surface. just like this.untitled.jpg
JayantaPoddar
MVP Esteemed Contributor
Hi Nazmul,
Try the following
While conversion of Multipatch to Raster, give the output cell size as low as about 0.01 m
Also Go to Environment > XY Resolution and Tolerance
XY Resolution: 0.01 meters
XY Tolerance: 0.001 meters
Then go with flow accumulation as mentioned by Xander Bakker
Jay
Think Location
