I have a raster that I want to clip to a county boundary (no data outside county). It is a stretched NDVI tif, so the values of the raster are 0-255. I tried using the Con function, but it produced an output raster with values from 6 to 66500-ish. I determined that what would work is the raster Clip tool and checking the 'Use Input Features for Clipping Geometry' box. The results are fine -- no data outside the county, correct values inside the county -- EXCEPT that the extent of the output raster is the extent of the county polygon, and I want it to be a different, larger extent (so as to be the same size as other raster datasets).
The Python Snippet comes out like this:
# Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the
# layer/table view within the script.
# The following inputs are layers or table views: "...a.tif", "...b.shp"
arcpy.Clip_management(in_raster="...a.tif", rectangle="677439.999999999 3721040 678360.000000007 3722960", out_raster="...c.tif", in_template_dataset="b.shp", nodata_value="256", clipping_geometry="ClippingGeometry", maintain_clipping_extent="NO_MAINTAIN_EXTENT")
I can replace all the dataset arguments with variables:
theInRaster = ...a.tif
theCntyShp = ...b.shp
theOutRaster = ...c.tif
arcpy.Clip_management(in_raster= theInRaster",
out_raster=theOutRaster,
in_template_dataset=theCntyShp,
Now, I want the rectangle argument to be equal to the extent of clip.tif. I tried setting the arcpy.env.extent to clip.tif and leaving the rectangle argument blank (""), but it went to the smaller extent of the polygon. So, I need to actually put 'something' in the rectangle coordinates. I tried setting theExtent to several things:
theExtent = arcpy.env.extent and then rectangle = theExtent #crashed ArcGIS completely
theExtentRaster = ...clip.tif and then rectangle = theExtentRaster #crashed ArcGIS completely
theDesc = arcpy.Describe(theExtentRaster)
theExtent = theDesc.extent and then rectangle = theExtent
or
theExtentString = str(theExtent.XMin) + ' ' + str(theExtent.YMin) + ' ' + str(theExtent.XMax) + ' ' + str(theExtent.YMax) and then rectangle = theExtentString
and also trying adding either single quotes or double quotes to theExtentString
all result in this error:
ExecuteError: ERROR 000622: Failed to execute (Clip). Parameters are not valid. ERROR 000628: Cannot set input into parameter rectangle.
So, clearly, there is SOME OTHER WAY to define the rectangle. I'm hoping someone out there can help.... Thanks.
