First of all, thanks for your response.
I have Cropland Data Layer, which is 30*30 meter satellite image.
I want to make a field-based panel data in order to see the crop rotation for specific crops in Kentucky at the end.
First, I was thinking to figure out how many fields are growing corn, soybean, and so on based on field boundary shapefile.
Since I have so many unnecessary fields (i.e., not for corn or soybean), I would like to delete those fields. (It is because
Second, I want to calculate how many pixels are located in each field in order to calculate total acres in each field based on number of pixels.
Based on your suggestion, I may able to test smaller datasets and extent. However, I have 92 counties based on field boundary shapefile. It means I need to repeat 92 times.
If you have better ideas, please let me know.
