Merging rasters - some issues
707
02-22-2017 05:39 AM
PrzemysławKłos
Hi!
I'm not sure if it's right place to ask my question but I have an issue with merging rasters.
As you can see in the first picture, I have 4 independent layers with symbol 0 having no color.
Using "Mosaic to new Raster" is doing something like this:
Mosaic to new raster window:
   All I want to have is to just merge those rasters into one file and have symbology like in first case.
Any suggestions?
JayantaPoddar
MVP Esteemed Contributor
What happens when you mosaic it using the Image Options Window?
Using the Mosaic button on the Image Analysis window
Export the image to a raster dataset. Change the stretch type in layer symbology, if required.
Think Location
PrzemysławKłos
Thanks for quick response!
After doing steps you mentioned, after several tries I got something like this:
It looks quite good, but trying to export or copy that raster follows to create awful output:
I keep "Copy raster" options default. How to improve the output?
