When I change the options under the Customize menu, in this case changing the default raster resampling to be nearest neighbor, the change is not saved. When I open ArcMap again, it has stayed with the same options as it originally had. This also happens if I change the default band combinations. When I tried changing the Data View options, those changes also are not saved.
Anyone else have this problem? Any potential solutions?
