Hi: I'm trying to add monthly precipitation (raster) data to the Nicaraguan municipalities (polygons). I have done this before with the state level and works perfectly. I checked the datum, environments, size of the files and everything seems to be fine. But each time I run the process I get a ???background geoprocessing operations did not complete due to an error"; then the process stops at 28% of advance and I get an empty output table.
Zonal Statistics as Table [000000_12301899]
# The following inputs are layers or table views: "adm2_nic", "prec9nic"
arcpy.ZonalStatisticsAsTable_sa("adm2_nic","ADM2_CODE","prec9nic","C:/LeptoNicGeoprocessing/GRID/lluvia9","DATA","ALL")
