Zonal Statistics: wrong MIN, MAX, MEAN values
3949
12-20-2016 01:06 AM
VitorFortunato
Hello!
I'm trying to run the Zonal Statistics as Table function using the following parameters:
- Input source: vector polygon feature class with neighborhoods in a city
- Zone field: OBJECTID
- Input raster: euclidean distance of a railway raster
- statistics type: ALL
However, all the statistics values seem wrong, as the vast majority of them have MIN value higher than the MAX value, which is impossible. That being said, all other values are wrong as well: RANGE, MEAN, STD and SUM.
What am I doing wrong?
here is a print screen of the evidence:
rail distance
AbdullahAnter
The result from  Zonal Statistics as Table is a table, and that table will has one required OBJECTID.
in your picture the table has two required OBJECTID.
so I think that the table is modified.
try again the tool and snapshot the original result.
DanPatterson_Retired
BUG-000095650 Zonal tools using the FID field gives incorrect results.
BUG-000095651 The Zonal Statistics tool is crashing ArcMap and ArcCatalog when the input zone data does not have a raster attribute table.
have been fixed in 10.5
I hope that table is the result of a join after the zonal statistics was calculated and not before it was calculated.  And every thing is in the same projection I hope? and it is projected and not in geographic coordinates... the list of places things can go wrong are numerous.
