Can I hide the floating text panel in a floating side car?
478
03-15-2023 03:05 PM
ReneePatrickTrailConsulting
I am building a floating side car and want one of the slides to appear without the floating text box over the full-screen image. Is that possible?
AbbyE_Esri
Hi @ReneePatrickTrailConsulting,
If you change the panel appearance to have a transparent background, then the floating panel will be invisible and you can leave the narrative panel blank.
This way, your slide will look like it is solely displaying the image with overlaying narrative panel.
Let me know how this works for you!
Abby
AbbyE_Esri
Abby
Perfect! That sounds like an excellent solution, thanks!
