Emergency Response Times Mapping
4680
07-31-2013 08:01 AM
MiguelGarcia
Greeting from City of Woodland, Ca,
I have a point feature class created from the incident response times for the City's Fire Engines Stations.
I would like to map the response times for each fire station, in a manner which looks similar to the example map created in Google Maps.
I have ArcGIS 10.1, with Advanced level licensing.
Miguel Garcia
RamB
Hi
here is your answer
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//004700000048000000
please use service areas feature of network analyst. You need a refined and detailed road network though.
regards,,
DavidAllen
"GIS Tutorial 2: Spatial Analysis Workbook" from Esri Press has a chapter on doing this exact type of analysis using data from the City of Ft. Worth. It also goes on to show statistical hot spot mapping as well as analysis with a spider diagram.
