Currently with a Microsoft Power automate (MSPA) flow that uses a connector for ArcGIS Survey123, the security token for the connector seems to only be valid for 30 days. After this time, the flow will fail due to an invalid token with the error:
"error": {
"message": "Missing required parameters: \"token\"",
"code": "001"
"success": false
Because the main reason for using a MSPA flow is to automate certain tasks, it would be ideal if this token would be valid either indefinitely, or for a much longer period of time, for example 1 year. When the token lapses, there seems to be only one way to get the connection to work again and that is this:
https://community.esri.com/t5/arcgis-survey123-questions/changes-to-survey123-connector-in-power-aut...
