Hi NPS LESES,
Based on your description, this is currently an expected behavior due to two known issues:
1. print map failed for ... "error":{"code":500,"message":"Error performing execute operation","details":[]}} indicates that the behind printing service has reaced its concurrent limitation, trying again later should fix the issue
2. However, I have not included the map in my print template. Currently, the report engine actually prints one map for each record there's no geopoint question in the survey ( there's still 0,0 in shape column)
We are trying to improve the workflow and performance now, should have some progress in the next 3.1 release.
