When I try to use a photo (taked with Survey123 or another app - like OpenCamera, f.e.) with annotations (setting "annotate" in "appearance" column - field type "image"), the EXIF data is lost. I believe that it's a bug in Survey123 because when I trying to take a photo in this field using Survey123, the GPS widget symbol appears in the upper-right corner of the device screen, however the EXIF data is removed by the annotation session before return the photo to the form.
Please let me know if I'm doing something wrong or when this problem will be solved.
Thanks.
