Appending Survey123 data and maintaining relationships
1457
07-20-2020 09:47 AM
BradleyManning1
New Contributor III
Hello,
I recently had to make changes to a survey I built that had a lot of begin repeats (various pieces of related equipment). I made schema changes to the survey which caused the survey to lose any submitted data to that point. Before publishing I downloaded the submitted surveys as a file gdb. I then published the new survey schema, but I needed to append the survey data I downloaded back in to the feature service.
I followed the steps here: How To: Append data to a Survey123 for ArcGIS survey from an existing survey with related tables to append the surveys back in, however I lost all of the relationships the survey originally had. So now, all of the data is appended in to the tables again, however, they are not related in anyway. I assume because when I appended them in, a new Global ID, or something along those lines.
Is there a way to append downloaded surveys back in to the surveys feature service, and maintain those relationships?
I am currently on version 3.9.120
Brad
JamesTedrick
Esri Esteemed Contributor
Hi Bradley,
One thing that can be done at the publishing step is to choose to use another GUID field instead of globalID as the parent relationship field - this would allow the relationship to persist across a change as you describe.
Using ArcGIS Pro, it is possible to maintain existing GlobalIDs using the Append Geoprocessing tool
Aside from the above, as part of the migration process, you can add an additional GUID field while the data is in a geodatabase to store the existing globalID; that field also needs to exist in the feature class.  After the data is loaded, you can create a lookup table between new globalID and existing globalID and update the destination fields with the new values (this is probably best done
BradleyManning1
New Contributor III
Thanks James, this makes sense. I was at the point where I was trying not to republish. This survey is for some interns we currently have and their time is limited. What I ended up doing was going to the items detail page and on the data tab, I simply copy and pasted the new parent global ID for each record that was missing the relationship. Not ideal, but it worked and I didn't have to republish and risk losing anything.
ZacharySutherby
Hello Bradley,
On top of what James said here are a few additional resources that may help out:
https://community.esri.com/thread/213108-loading-survey13-data-with-related-tables-into-a-new-form#c...
https://www.youtube.com/watch?v=S5V6MIrAKCk&t=1s
I will be updating that How To article to include the ArcGIS Pro workflow.
Thank you,
Zach
Thank you,
Zach
DougBrowning
MVP Esteemed Contributor
Also this post may help  https://community.esri.com/thread/202815-preserving-a-globalid-while-moving-data-between-feature-cla...
The other option to to change to a different key that you can reproduce.  I do not use globalids for keys for all the reasons in this post https://community.esri.com/thread/166958
Hope that helps
LLyons
New Contributor III
Anyone have a new link to the previous documentation: How To: Append data to a Survey123 for ArcGIS survey from an existing survey with related tables  ? I used it just a few months ago and still need the information but it's no longer showing.
