I think there could be two separate issues here:
1- Mobile app fails to submit. Please make sure you have version 2.4.71 installed in your device. You may be running into an issue that was addressed in this update.
2- The Survey123 website fails to draw features if the logged in user is the owner of the survey. We are currently investigating this. It looks like there is a software defect in ArcGIS Online that is affecting the Survey123 website.
While issue #2 is resolved, I suggest you try the following:
- Revert the restrictions in your surveys hosted feature layer (editors should be able to see all features)
- Create a Hosted Feature Layer View from your feature layer
- Apply security restrictions to your view
- Using Survey123 Connect, build a survey on top of the view and have people in the field work with it
- In the Survey123 website, use the original survey to look at the data and ignore the survey you created in step 4
Expect a call from Margaret Gregory today so we can follow up on the problem.
