HiJames Tedrick, I too am having issues with the calculations on the webform not calculating answers from previous questions, whereas the same survey using the Survey123 app on my mobile device/computer does work as expected. It would be nice to understand the requirements, my error, or if there is an issue?
As noted the Survey123 apps show the calculation (in my case the difference between two time fields, when a lift is reopened). The fields on the web form do not update as expected. For client reasons, I want to be able to rely on web version rather than the app so this is a bit of an issue.
I have tried to use the number() function and did not change to the output. For example,
int(number(${StartTime}) - number(${StopTime})) div (1000*60)
It is as if the webform is not dynamic?
Thoughts, appreciated.
Web form:
