Can I 'comment out' a line in Survey123 Connect?
1303
10-19-2017 10:17 PM
JamesWilson2
In the same way that I can 'comment out' or 'block comment' lines of code, is it possible to 'comment out' rows in excel in Survey123 Connect while I build/test forms?
that way if I haven't quite nailed down calculations or expressions, or I am doing frequent tests of something at the end of a form, I don't have to go through filling out the first half of the form as I could choose to ignore rows altogether.
maybe a type = ignore option that would make survey123 ignore the row?
Cheers
James
JamesTedrick
Esri Esteemed Contributor
Hi James,
We currently don't have the capability to do this in Survey123 Connect.  It's an interesting idea- I'll add this as a potential enhancement to Survey123.  You may want to register an idea in ArcGIS Ideas for this as well.
by Anonymous User
Not applicable
James,
I think this would be an extremely helpful for documenting steps of how the Survey123 form was created; similar to how coders comment out sections within their codes. What about adding a column that would allow for coding comments also?
Sometimes it can months before I look at some of the forms and having a few notes within the actual survey on why I did something would be beneficial to both myself and others. I guess this would be a different request; to add a column for documentation purposes.
Thanks!
Mike
JamesWilson2
you could possibly add a 'comment' with a hidden field and the 'bind::Esri:esriFieldType' = null. then you could write whatever you want in the label field. could that work?
Cheers
James
