Hi @abureaux
It has been a fun adventure learning more about the search() functionality. Thank you for pointing me in that direction. Broadly speaking, I think your suggestion will work fine.
I am seeing two bits of functionality, though, that are a bit nettlesome.
- When the survey loads and before any Company is selected, all possible Work Order Numbers are available in the dropdown. Once a company is selected, the list is filtered as expected, but i'm a bit bothered by having all work order numbers present prior to selection. I certainly could hide the Work Order question until a Company is selected, but the question is 'foundational' to the survey and i'm a bit hesitant to hide/display the question depending on the state of the Company selection
- If i select a company, then make a Work Order Number selection and then clear the Company selection, the selected Work Order Number remains visible. Once i make a new Company selection, the selected work order number is cleared and all is as expected. I would expect the Work Order Number to be cleared if the Company selection is cleared
Those two items aren't enough to prevent me from using the Search() functionality, but just troublesome enough to slightly irk me. Do you have any suggestions for making the Work Order Number list blank until, and only if, a company name is selected?
