I have a form with multiple groups and repeats that let you collect multiple geopoints. By default the report print each geopoint separately but I want to show all the points in a single map because otherwise it won't make sense displaying them separately.
How can I do that? I found this from the documentation ${geopoint_question | mapSettings:"10df2279f9684e4a9f6a7f08febac2a9":100000}
geopoint_question is the name of the question that let you drop the point and in the object ID (in this case "10df2279f9684e4a9f6a7f08febac2a9" I put the ID of the map that contains the feature layer.
It gives me an error when I try to upload the report template. Failed to parse because it cannot find the geopoint_question or something similar.
I appreciate your help
