Hi James,
The errors happen when I try to create or publish surveys in survey123 connect on my portal.
This error occurs when I try to create a survey from an existing feature service:
The error 500 occurs when I try to publish a completely new survey:
Note: When I look in my Portal I find this. So there is something getting published.
When i then try to "republish" the survey I get the error 400:
I also got the log files attached to my original post.
They have created a feature service. I can't really read to much out of them otherwise.
And the error 498 ("Invalid token") occurs when I try to create a survey on top of an existing example service from esri:
Yes, the service is on an federated server. How do I get my feature service from my federated server on my data store to solve this problem?
I don't know if there is something wrong with my portal. There is no problem to use Collector with this portal.
Thanks in advance
Leo
