Error loading survey 123
1796
18
06-13-2023 06:15 AM
Ed_
by MVP Regular Contributor
I have been using Survey 123 as an embedded app in Experience. It was showing up fine until yesterday but today I am getting this error.
How can I fix this?
Question | Analyze | Visualize
Tags (3)
BarbaraWebster1
Hi @Ed_ @CristianChavarini @mrobar @AlexUreAl, the fix for the issue that was causing the "HTTP 504: UNKNOWN_ERROR" error has been deployed. Can you try loading the webform again and let us know if are still running into issues?
AlexUreAl
New Contributor II
It works again!
BarbaraWebster1
Great, thanks for confirming!
mrobar
New Contributor II
The fix so far seems to do his job. We are able to use all of functionalities.
And we are looking forward to test all the new features that were added and are gathered in a post from this morning. Especially we love the possible integration with RFID tags and photography AI.
BarbaraWebster1
Thanks for confirming, we've added new sample surveys for both these new features to the Connect sample gallery to help with getting started.
Yann-EricBoyeau
Hi Barbara,
Would you please confirm if the bug is the same here : https://community.esri.com/t5/arcgis-survey123-questions/survey-embedded-in-dashboard-no-longer-edit...
We are still having issues with surveys embedded in Enterprise Dashboards.
Thank you
BarbaraWebster1
Hi @Yann-EricBoyeau The question you linked to was created last August, so I don't think it was related to the 2023 June release. Can you provide some more details about the behavior you're seeing?
Yann-EricBoyeau
We found that non-public surveys (from survey123.arcgis.com) embedded in a non-public 10.9.1 Enterprise dashboard does not display anymore. Everything was working before last AGOL upgrade.
looks like url for sharing survey :
https://survey123.arcgis.com/share/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx?portalUrl=https://myportal.mydomain.com/arcgis
does not work anymore (does not ask for authentication or reuse dashboard credentials)
Yann-EricBoyeau
we have now a referenced bug for this issue : BUG-000159240 - Unable to add the Map/feature service from a federated server with store credentials as an URL to Portal for ArcGIS when using AD user logins
