Is it possible to compare image sizes using an if statement in a repeat based on an image question with an appearance of multiline? Most photos are taken in landscape mode but sometimes it is in portrait. I don't want to squish the portrait photos.
${#photos}
${if $file | getValue:"height" > $file | getValue:"width"} ${$file | size:400:600} ${/}
${if $file | getValue:"width" > $file | getValue:"height"} ${$file | size:600:400} ${/}
Usually, I get this error when uploading the template:
Error: An error occurred when checking the report template. The end tag ${/} is unopened.
Sometimes it loads but fails on the generating of the report:
An error occurred when rendering by the report engine. Failed to parse ${if $file | getValue:"height" > $file | getValue:"width"} since it is an invalid expression.
