File questions in web form not honoring relevant setting
1261
13
04-18-2023 11:25 AM
jvarasanz
Good afternoon.
Since yesterday evening, file questions with a relevant expression are not honoring this setting in web forms.
Sample xlxs attached.
Javier
2 Solutions
ZhifangWang1
@jvarasanz ,
Thanks for providing the feedback. I can reproduce the issue by using your XLSForm file.
We are working on a fix and will let you know the plan soon.
ZhifangWang
Hi @jvarasanz , @KenBouchard , @ChelseaRozek ,
The fix to this issue (BUG-000157639) is now available on the Survey123 website https://survey123.arcgis.com
Thanks again for all your feedback and testing.
Regards,
Zhifang
ZhifangWang1
@jvarasanz ,
KenBouchard
Same issue here since yesterday!
Ken
ChelseaRozek
MVP Regular Contributor
Same here, two of our image questions are suddenly set to display none in the web form even when relevant conditions are met. The file question is fine.
ZhifangWang
@jvarasanz @KenBouchard @ChelseaRozek ,
We had a fix to this issue installed on the Beta website https://survey123beta.arcgis.com , can you please test if it works for your surveys?
KenBouchard
Yes!  Its working on the Beta website. (For me, can't comment for the other ones)
jvarasanz
Affirmative.
Thanks for the quick response on this.
Javier
ChelseaRozek
Yes, both of my image questions work on the beta site and the file question remains working. Thanks @ZhifangWang !
jvarasanz
Good afternoon.
I've just wanted to check if this has already been resolved. Everything seems to be working in the beta website, but I haven't noticed anything different in production. Do we need to republish our Surveys?
Kind regards,
Javier
ZhifangWang
Regards,
Zhifang
