How to export Survey123 to CSV using field names (not labels) for column headers?
952
10-07-2019 09:31 AM
AndreaRyffel
New Contributor II
Is there a way to export Survey123 data to CSV using the field names (instead of labels) as column names?
I would like to use data from Survey123 to prepopulate the next data input with default values using pulldata(). In order to work, pulldata() requires correctly formatted column headers (aka field names, not labels).
Thanks for any hints!
JamesTedrick
Esri Esteemed Contributor
Hi Andrea,
This is not possible via the tools in the Survey123 web page or ArcGIS Online.  This is possible using ArcGIS Pro's export functions.
AndreaRyffel
New Contributor II
Hi James,
I'm very late, but anyway: Thank you for your answer
