Is there a way to export Survey123 data to CSV using the field names (instead of labels) as column names?
I would like to use data from Survey123 to prepopulate the next data input with default values using pulldata(). In order to work, pulldata() requires correctly formatted column headers (aka field names, not labels).
Thanks for any hints!
